Bobcat CT5550 suddenly stopped
/ Bobcat CT5550 suddenly stopped #1
Michael Michaelis
Bobcat 5550
Hello I have a Bob cat CT5550 I was using the box blade for about 2 hours with rpm set at 2300, when tractor suddenly stopped, no warning lights sounds prior to shut off. I cant start it now, there is both diesel as well as oil,. The batterie is also sufficient, the tractor turns over however it will not start.
Anyone have some suggestions?
/ Bobcat CT5550 suddenly stopped #2
Sounds like some type of safety sensor. Possibly with the seat?
/ Bobcat CT5550 suddenly stopped #3
If the tractor turns over your safeties are probably all satisfied. Since it died while in use the fuel stop solenoid may be suspect.
Ok that makes sense.... I bought the tractor new last year and so i still have warranty on the machine... I will call the company today hopefully it is a quick fix for them to get me back up and running. I will post the results as they come in. thanks for your input
/ Bobcat CT5550 suddenly stopped #7
my 2538 did thisabout a month ago , was brush hogging when it died , turns out the fuel i had just put in was bad. Had to drain entire fuelsystem and replace filters.
YANMAR 60" TILLER (A64280)
YANMAR 60" TILLER...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
1R CULTIVATOR, 3PT (A64280)
1R CULTIVATOR, 3PT...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2003 International 4300 National Crane 326A 7 Ton Straight Boom Crane Truck (A61573)
2003 International...
