Bobcat CT450 - Fuel Filter Leaks.
   / Bobcat CT450 - Fuel Filter Leaks. #1
SirMaxwell
TN
Bobcat CT450 HST
I just changed the fuel filter with a "Kioti" part, and I get drips.
I would have thought there would be a seal/gasket/o-ring, but the original did not have one, or at least I did not remove one and none are laying around.
I've looked for an exploded view of the canister, but can't find one.
Anyone help out here? Anything I can get local that might work?
Thanks,
Max
   / Bobcat CT450 - Fuel Filter Leaks. #2
   / Bobcat CT450 - Fuel Filter Leaks. #3
Large o-ring Bobcat 6694162, Kioti 04811-50650, ID 64mm, od 70mm. Small o-ring Bobcat 6694147, Kioti 04811-00160, couldn't come up with size. I refuse to be sued if wrong information. :D
   / Bobcat CT450 - Fuel Filter Leaks. #4
PT# 6694162 :thumbsup:
Thanks@winston1 - So what you are saying is use Ultra Black forma a gasket, right? :p
Biggest wonder is what happened to the Big o-ring. it is no where to be found. Thought it was suspicious not having a gasket.
Oh btw - I talked with my attorney and he said you can refuse all you want, it won't slow him down a bit. :laughing:
Max
jabonne - what is that number?
   / Bobcat CT450 - Fuel Filter Leaks. #7
Double check that the old filter top is still stuck up in the housing. Its hard to see but double check. Had it happen to me.
2016 FORD F-150 (A52472)
2016 FORD F-150...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
378653 (A51573)
378653 (A51573)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
