Bobcat CT450 - Fuel Filter Leaks.
   / Bobcat CT450 - Fuel Filter Leaks. #1
SirMaxwell
TN
Bobcat CT450 HST
I just changed the fuel filter with a "Kioti" part, and I get drips.
I would have thought there would be a seal/gasket/o-ring, but the original did not have one, or at least I did not remove one and none are laying around.
I've looked for an exploded view of the canister, but can't find one.
Anyone help out here? Anything I can get local that might work?
Thanks,
Max
   / Bobcat CT450 - Fuel Filter Leaks. #2
   / Bobcat CT450 - Fuel Filter Leaks. #3
Large o-ring Bobcat 6694162, Kioti 04811-50650, ID 64mm, od 70mm. Small o-ring Bobcat 6694147, Kioti 04811-00160, couldn't come up with size. I refuse to be sued if wrong information. :D
   / Bobcat CT450 - Fuel Filter Leaks. #4
PT# 6694162 :thumbsup:
Thanks@winston1 - So what you are saying is use Ultra Black forma a gasket, right? :p
Biggest wonder is what happened to the Big o-ring. it is no where to be found. Thought it was suspicious not having a gasket.
Oh btw - I talked with my attorney and he said you can refuse all you want, it won't slow him down a bit. :laughing:
Max
jabonne - what is that number?
   / Bobcat CT450 - Fuel Filter Leaks. #7
Double check that the old filter top is still stuck up in the housing. Its hard to see but double check. Had it happen to me.
2016 FORD F550 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F550...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
2001 John Deere M665 (A50120)
2001 John Deere...
SKID STEER BUCKET (A52472)
SKID STEER BUCKET...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2012 International DuraStar 4400 Service Truck with Crane, VIN # 1HTMKAAN2CH076971 (A51572)
2012 International...
