Bobcat CT450 - Fuel Filter Leaks.
   / Bobcat CT450 - Fuel Filter Leaks. #1
SirMaxwell
TN
Bobcat CT450 HST
I just changed the fuel filter with a "Kioti" part, and I get drips.
I would have thought there would be a seal/gasket/o-ring, but the original did not have one, or at least I did not remove one and none are laying around.
I've looked for an exploded view of the canister, but can't find one.
Anyone help out here? Anything I can get local that might work?
Thanks,
Max
   / Bobcat CT450 - Fuel Filter Leaks. #2
   / Bobcat CT450 - Fuel Filter Leaks. #3
Large o-ring Bobcat 6694162, Kioti 04811-50650, ID 64mm, od 70mm. Small o-ring Bobcat 6694147, Kioti 04811-00160, couldn't come up with size. I refuse to be sued if wrong information. :D
   / Bobcat CT450 - Fuel Filter Leaks. #4
PT# 6694162 :thumbsup:
Thanks@winston1 - So what you are saying is use Ultra Black forma a gasket, right? :p
Biggest wonder is what happened to the Big o-ring. it is no where to be found. Thought it was suspicious not having a gasket.
Oh btw - I talked with my attorney and he said you can refuse all you want, it won't slow him down a bit. :laughing:
Max
jabonne - what is that number?
   / Bobcat CT450 - Fuel Filter Leaks. #7
Double check that the old filter top is still stuck up in the housing. Its hard to see but double check. Had it happen to me.
Electric Mobility Scooter (A51694)
Electric Mobility...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
CENTRAL PNEUMATIC  GAS 135 PSI (A52472)
CENTRAL PNEUMATIC...
