Bobcat CT335 complaint. Suggestions
   / Bobcat CT335 complaint. Suggestions #1
John White
Newark, Oh
Bob Cat Ct335
I Just purchased a CT335. 2012. It has some grill damage which I patched up and fixed most of it but I need the lower screen. Some one had cut a hole through the screen to hook up a battery charger and ran the cord through it plus it is bent up pretty good.This tractor is 8 years old. Bobcat says it is no longer available. I Called several dealers through out the US. and no one has that item. You would think that would be item that would still be available. So if you have a Bobcat tractor be very careful getting around any thing that would damage your grill. I went to Kioti because people said they were made by Kioti, they are not the same. If any one knows where I might get one please let me know. The upper grill (screen) and the plastic frame are still available.
   / Bobcat CT335 complaint. Suggestions #2
That sucks. Might get a body shop to fab it and put it in for you. Might cost a good bit.
   / Bobcat CT335 complaint. Suggestions #3
I don't have any idea what the original looks like, but it seems you could fab it yourself fairly easily from thin perforated metal. That should be readily available.
   / Bobcat CT335 complaint. Suggestions #4
Heres a quick comparison of the CT335 and DK35se, they are pretty close
CT335.JPG Bobcat CT335
Kioti Dk45se.JPG Kioti DK35se
Bobcat ct335.jpg Bobcat CT335
Kioti dk35se.JPG Kioti DK35se
Heres a grill break down of a kioti from Nolts if it helps.
OEM Parts Nolt's Power Equipment LLC & Perry Power Equipment
and the upper part
   / Bobcat CT335 complaint. Suggestions #5
Here is a clearer pic of the Bobcat, grill and screen sure look the same to me.
If the Kioti screen is not exactly the same it should be close enough to make it fit.
View attachment 642249 Bobcat CT335
View attachment 642250 Kioti DK35se
View attachment 642254 Bobcat CT335
View attachment 642255 Kioti DK35se
and the upper part
Thanks xcgreen: That is what I was looking for. I contacted them and they said it will work, again thanks
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
HONDA EU2200 INVERTER (A50854)
HONDA EU2200...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
International 4700 Vibra Tiller (A51039)
International 4700...
