Tractor Sizing Bobcat CT122 vs CT225/30 and Kioti CK27/30
   / Bobcat CT122 vs CT225/30 and Kioti CK27/30 #21
Well tomorrow I go to buy the local CK30 and try to get a buy on the attachments. We are going this way after talking with a couple of guys out in my area and their big issue was how steep our hill is, stability and the composition of our soil. They also saw it as an investment and said I would never regret the extra power. One even suggested the next model bigger. I am going to get a canopy, 60" rear blade and front forks. I will shop around for the mower and post auger. What are the thoughts on a scarifier? It makes sense that it would break up the soil for gradeing but? I also have looked at the grading scrapers. Those seem cool but there are so many choices of goodies for moving dirt around. I have a little bit of road to build and some elevations and grades to work for drainage. They still have to mount the loader and I will also see about having the tires filled with beet juice for more weight down low.
Thanks,
Gene
Gene, DO NOT :thumbdown: get a 60" rear blade for your CK30. :eek: A 60" box blade yes, but not a rear blade. Get at a minimum of a 72" and I would go with an 84" rear blade, as heavy as you can afford which means higher quality and much more $$$$. You want a blade that will do something, not one that will only move loose material.
If you need to do some road building, you should check into getting a good heavy 60"-66" box blade. Around 600-800lbs, that along with the rear blade and you will be set pretty good for working on your roads. Get a land plane grading scraper later on down the road. Great for maintaining a road, not needed for building the roads though.
You should double check about rear remotes also. Sooner or later your going to want 2 of them. ;)
   / Bobcat CT122 vs CT225/30 and Kioti CK27/30 #22
Boy Mr. Wallace, I had heard you were kind of a jerk, now you just proved it. I'm glad you know everything about tractors. I know a little more than you think I do. Only been in the tractor business for 25 yrs. At least I know now Bobcat has extended through 2016. I won't make that mistake again.
I know about Daedong and who builds what. Sorry I said the wrong thing.
Bought the tractor today! They had everything but the pallet forks and canopy. Ended up going with a 72" rear blade. with the blade angled it is still wider than the tractor which will be great come winter! I also has tilt and side to side adjustment. I am going to rent a box blade and see how we get along as well as borrow a grader attachment. I am still going to add one of the tooth blade sets from W.R.Long not sure which one. Also looked at their tree spade. Has anyone used one?
Thanks,
Gene
   / Bobcat CT122 vs CT225/30 and Kioti CK27/30 #24
congrats. Post some photos!
So here it is! They just started mounting the loader and ordered the goodies!:thumbsup:
   / Bobcat CT122 vs CT225/30 and Kioti CK27/30 #26
Give 'em **** Wallace
And here is the front yard a couple of little rolls in the hill to get up to the house with a steep gully to the left(west) and steeper behind the house. It isnt the most aggressive topography but probably because the ground is mostly clay and shale. We have a lot of projects to button up before snow flie! New windows in the bottom half and a new section of road to build. plus plowing to prep for and dead trees to gather!
   / Bobcat CT122 vs CT225/30 and Kioti CK27/30 #28
Looks good.
Congrats and Welcome to the Pack!
   / Bobcat CT122 vs CT225/30 and Kioti CK27/30 #29
I agree on the blade size. I had a 6' rear blade for my 28HP tractor and when you put a angle on it it would not cover the wheel tracks. I now have a 7' blade and its perfect.
Nice tractor. I am jealous.
Chris
   / Bobcat CT122 vs CT225/30 and Kioti CK27/30 #30
Good looking tractor.
Alligator Statue (A55853)
Alligator Statue...
2016 Case IH Puma 240 (A53317)
2016 Case IH Puma...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
(4) METAL STORAGE SHELVES (A57192)
(4) METAL STORAGE...
UNUSED FUTURE FT-ZP20 20' X 30' GARAGE CARPORT (A57193)
UNUSED FUTURE...
Bush Hog RZ60 (A56469)
