MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,675
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Well tomorrow I go to buy the local CK30 and try to get a buy on the attachments. We are going this way after talking with a couple of guys out in my area and their big issue was how steep our hill is, stability and the composition of our soil. They also saw it as an investment and said I would never regret the extra power. One even suggested the next model bigger. I am going to get a canopy, 60" rear blade and front forks. I will shop around for the mower and post auger. What are the thoughts on a scarifier? It makes sense that it would break up the soil for gradeing but? I also have looked at the grading scrapers. Those seem cool but there are so many choices of goodies for moving dirt around. I have a little bit of road to build and some elevations and grades to work for drainage. They still have to mount the loader and I will also see about having the tires filled with beet juice for more weight down low.
Thanks,
Gene
Gene, DO NOT :thumbdown: get a 60" rear blade for your CK30.
If you need to do some road building, you should check into getting a good heavy 60"-66" box blade. Around 600-800lbs, that along with the rear blade and you will be set pretty good for working on your roads. Get a land plane grading scraper later on down the road. Great for maintaining a road, not needed for building the roads though.
You should double check about rear remotes also. Sooner or later your going to want 2 of them.
