Bobcat CT 235 rear wheel hub seal leak
   / Bobcat CT 235 rear wheel hub seal leak #11
So— I’m assuming that there is hyd fluid in the case (hense the leak). Impressive that the case does leak w/out a gasket.
I replaced my left rear axle seal back in 2018.
No leaks on my axle case using the Permatex grey. (I did follow the directions on the gasket maker tube)
   / Bobcat CT 235 rear wheel hub seal leak #12
Lots of my mating surfaces on my Kubota's are gasketless too. I use a thin smear of 3 Bond anaerobic sealant and call it good.
M
My axle case had no gasket.
I used Permatex Ultra Grey (maximum torque) gasket maker
I ordered my Oring and axle seal from Michigan Iron.
Isn't the Kioti CK 35 basically the same machine as the CT 235 ?
Called Michigan and told the Lady I have a Bobcat, which is a Kioti. Gave her the Bobcat #’s, and she basically said go away, can’t help ya unless I have Kioti #’s. I was told those #’s are non crossable.
   / Bobcat CT 235 rear wheel hub seal leak #14
Their website has a parts finder that I use a lot, should be able to find what you need.
   / Bobcat CT 235 rear wheel hub seal leak #15
I have never called them.
I order online with parts finder.
PUMP JACK (A48992)
PUMP JACK (A48992)
2009 Chevrolet Traverse LS SUV (A48082)
2009 Chevrolet...
2007 CHEVROLET KODIAK C6500 (INOPERABLE) (A48992)
2007 CHEVROLET...
2013 FORD F-550 SUPER DUTY XL BUCKET TRUCK (A50459)
2013 FORD F-550...
LOT LOCATIONS (A50046)
45017 (A48082)
45017 (A48082)
