Bobcat CT 235 rear wheel hub seal leak
   / Bobcat CT 235 rear wheel hub seal leak #11
So— I’m assuming that there is hyd fluid in the case (hense the leak). Impressive that the case does leak w/out a gasket.
I replaced my left rear axle seal back in 2018.
No leaks on my axle case using the Permatex grey. (I did follow the directions on the gasket maker tube)
   / Bobcat CT 235 rear wheel hub seal leak #12
Lots of my mating surfaces on my Kubota's are gasketless too. I use a thin smear of 3 Bond anaerobic sealant and call it good.
M
My axle case had no gasket.
I used Permatex Ultra Grey (maximum torque) gasket maker
I ordered my Oring and axle seal from Michigan Iron.
Isn't the Kioti CK 35 basically the same machine as the CT 235 ?
Called Michigan and told the Lady I have a Bobcat, which is a Kioti. Gave her the Bobcat #’s, and she basically said go away, can’t help ya unless I have Kioti #’s. I was told those #’s are non crossable.
   / Bobcat CT 235 rear wheel hub seal leak #14
Their website has a parts finder that I use a lot, should be able to find what you need.
   / Bobcat CT 235 rear wheel hub seal leak #15
I have never called them.
I order online with parts finder.
500BBL WHEELED FRAC TANK (A48992)
500BBL WHEELED...
2018 Maserati Ghibli Sedan (A46684)
2018 Maserati...
Massey Ferguson 2650, 4WD, Loader, Canopy (A47371)
Massey Ferguson...
2007 Ford Fusion SE Sedan (A48082)
2007 Ford Fusion...
Woods 3pt 6ft Finish Mower (A49251)
Woods 3pt 6ft...
Galvanized Pipe (A49251)
Galvanized Pipe...
