Bobcat Ct 225 - Reverse speed problem too slow
   / Bobcat Ct 225 - Reverse speed problem too slow #1
hb2
Rouyn-Noranda (Qc) Canada
Bobcat CT225
Hello everyone!
I have just purchased the Bobcat CT 225 (2009) tractor.
It's really slow to REVERSE. Even when I put the transmission on high. About 3-4 km / h (1.5 m / h).
Is there an adjustment to be made to resolve this problem?
Thank you !
Also if there is anyone who needs the user manual, I have a digital version (PDF).:)
   / Bobcat Ct 225 - Reverse speed problem too slow #2
Not sure it is your problem but here is the adjustment procedure from the manual. I believe I have read of someone having a bent pedal before, might want to check that out.
   / Bobcat Ct 225 - Reverse speed problem too slow #3
Check the pedal. We have seen this many times. If the previous owner stood on the back side of the pedal, it can bend down and limit your reverse speed.
Hope this helps
Thank you michiganiron ll try I appreciate your help
Thank you winston1, I will try it !
   / Bobcat Ct 225 - Reverse speed problem too slow #6
My pedal was bent when i bought mine. Both forward and reverse were slow. Very easily fixed. I've considered beefing up the pedal by welding on some steel.
   / Bobcat Ct 225 - Reverse speed problem too slow #7
Hope this helps
WOW, it makes you wonder what else Bobcat skimped on!!..
   / Bobcat Ct 225 - Reverse speed problem too slow #9
2018 HINO 268 26FT BOX TRUCK (A51222)
2018 HINO 268 26FT...
CAT RM-300 (A50854)
CAT RM-300 (A50854)
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2005 INTERNATIONAL DURASTAR 4300 (INOPERABLE) (A50854)
2005 INTERNATIONAL...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A51039)
2018 Dodge Ram...
