Bobcat Ct 225 - Reverse speed problem too slow
   / Bobcat Ct 225 - Reverse speed problem too slow #11
Great Thread! Thanks for the headsup!
My CT225 is slower than CRAP in REVERSE!
Will check the pedal!
Thanks!
   / Bobcat Ct 225 - Reverse speed problem too slow #12
Reverse speed should be approximately 50% of forward speed at same RPM or gear range.
   / Bobcat Ct 225 - Reverse speed problem too slow #13
   / Bobcat Ct 225 - Reverse speed problem too slow #14
Well, I feel like a BIG DUMMY! Finally got my CT225 tractor out, to check my foot throttle.
The 2 bolts on the bottom holding it on, were just about out.
Tightened them up, and WOW! Big ole difference, foward AND reverse!
I've got to take a day and go over this thing.
Last major bolt problem was the entire loader assembly.
It was just flopping barely on after digging large hole to bury my horse.
Almost buried my loader with my horse, Lol.
Just an FYI!
CHECK UR BOLTS!
My tractor only has 501hrs.
Thanks again for bringing this thread up!
Sure helped me!
Terry
Good evening everyone !
Finally the problem is solved.
The two bolts that hold the pedal in place were unscrewed.
I replaced everything in its place and everything is back to normal.
Thank you all for your advice.
   / Bobcat Ct 225 - Reverse speed problem too slow #16
Sorry to say, but GLAD U had the problem!
It fixed mine!
So glad UR's was the easy fix too.
Im going to go back, and put Blue loctite on my threads.
It was COLD, when I tightened them up.
Check UR other bolts too, when U can!
Take care!
It fixed mine!
Take care!
Thx !
204158 (A57193)
204158 (A57193)
Hose Reel (A55758)
Hose Reel (A55758)
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A57880)
2020 INTERNATIONAL...
Metal Bigfoot with Flag Lawn Art (A55853)
Metal Bigfoot with...
2018 Ford Transit 150 Cargo Van (A55852)
2018 Ford Transit...
UNUSED JCT HYD AUGER (A57193)
UNUSED JCT HYD...
