Bobcat Ct 225 - Reverse speed problem too slow
/ Bobcat Ct 225 - Reverse speed problem too slow #1
hb2
Rouyn-Noranda (Qc) Canada
Bobcat CT225
Hello everyone!
I have just purchased the Bobcat CT 225 (2009) tractor.
It's really slow to REVERSE. Even when I put the transmission on high. About 3-4 km / h (1.5 m / h).
Is there an adjustment to be made to resolve this problem?
Thank you !
Also if there is anyone who needs the user manual, I have a digital version (PDF).:)
/ Bobcat Ct 225 - Reverse speed problem too slow #2
Not sure it is your problem but here is the adjustment procedure from the manual. I believe I have read of someone having a bent pedal before, might want to check that out.
/ Bobcat Ct 225 - Reverse speed problem too slow #3
Check the pedal. We have seen this many times. If the previous owner stood on the back side of the pedal, it can bend down and limit your reverse speed.
Hope this helps
Thank you michiganiron ll try I appreciate your help
Thank you winston1, I will try it !
/ Bobcat Ct 225 - Reverse speed problem too slow #6
My pedal was bent when i bought mine. Both forward and reverse were slow. Very easily fixed. I've considered beefing up the pedal by welding on some steel.
/ Bobcat Ct 225 - Reverse speed problem too slow #7
Hope this helps
WOW, it makes you wonder what else Bobcat skimped on!!..
/ Bobcat Ct 225 - Reverse speed problem too slow #9
/ Bobcat Ct 225 - Reverse speed problem too slow #11
Great Thread! Thanks for the headsup!
My CT225 is slower than CRAP in REVERSE!
Will check the pedal!
Thanks!
/ Bobcat Ct 225 - Reverse speed problem too slow #12
Reverse speed should be approximately 50% of forward speed at same RPM or gear range.
/ Bobcat Ct 225 - Reverse speed problem too slow #13
/ Bobcat Ct 225 - Reverse speed problem too slow #14
Well, I feel like a BIG DUMMY! Finally got my CT225 tractor out, to check my foot throttle.
The 2 bolts on the bottom holding it on, were just about out.
Tightened them up, and WOW! Big ole difference, foward AND reverse!
I've got to take a day and go over this thing.
Last major bolt problem was the entire loader assembly.
It was just flopping barely on after digging large hole to bury my horse.
Almost buried my loader with my horse, Lol.
Just an FYI!
CHECK UR BOLTS!
My tractor only has 501hrs.
Thanks again for bringing this thread up!
Sure helped me!
Terry
Good evening everyone !
Finally the problem is solved.
The two bolts that hold the pedal in place were unscrewed.
I replaced everything in its place and everything is back to normal.
Thank you all for your advice.
/ Bobcat Ct 225 - Reverse speed problem too slow #16
Sorry to say, but GLAD U had the problem!
It fixed mine!
So glad UR's was the easy fix too.
Im going to go back, and put Blue loctite on my threads.
It was COLD, when I tightened them up.
Check UR other bolts too, when U can!
Take care!
It fixed mine!
Take care!
Thx !
2022 Case TV450B (A64126)
2022 Case TV450B...
159115 (A60430)
159115 (A60430)
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2022 EZ-GO ELITE...
