Bobcat backhoe safety chain?
/ Bobcat backhoe safety chain? #1
dirt ditch
The pictures I see of bobcat backhoes mounted on bobcats have a chain on the base of the frame. The 709 I bought has this chain and a slotted bracket to hook it in. Am I right in assuming this chain is to be wrapped around the QA plate of the bobcat and the bottom of the frame of the backhoe attachment?
Thanks that's what I figured. I have ordered an operator manual from the dealer.
/ Bobcat backhoe safety chain? #4
As you probable suspected the chain keeps the hoe on the SSL in the event the locks fail or are forgotten. There was a few injuries from hoes rolling back and pinning the operator against the cab. There was a recall on early 709's to install a flow valve on it to only allow operation of the hoe when firmly attached to the SSL. Your new hoe may have this.:thumbsup:
I went out and looked. This hoe does have the safety valve. Thanks for the description.
UNUSED RAYTREE RMH680 HYD HAMMER (A62131)
UNUSED RAYTREE...
2011 Chevrolet Silverado 1500 Truck (A63116)
2011 Chevrolet...
POLY TANK ON SADDLE MOUNT (A62131)
POLY TANK ON...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
UNUSED RAYTREE RMSG29 HYD STUMP GRINDER (A62131)
UNUSED RAYTREE...
Caterpillar 259D (A62180)
Caterpillar 259D...
