Bobcat B250 problem PLEASE HELP
/ Bobcat B250 problem PLEASE HELP #1
Orangelandscaping
Orange ct
Bobcat b250
Hello I recently purchased a bobcat b250 tlb and reverse doesn't work. When I push the reverse pedal the backup siren works but nothing happens. All the other hydro functions work fine but what I did notice is that the yellow push to drive button lights up when engaged as usual, but cuts out when reverse is engaged and when the pedal is pushed all the way forward. When the pedal is pushed all the way forward the wheels stop spinning also. This leads me to believe that it is a electrical issue. Any input would be greatly appreciated thanks.
/ Bobcat B250 problem PLEASE HELP #2
I don't believe it is a electrical issue. I had a similar problem and the problem was in the shift linkage.
What shift linkage? You mean the valve body for the pedal?
/ Bobcat B250 problem PLEASE HELP #4
I'll check tomorrow when i go down to the shop. I believe I still have the paperwork on the repairs. as I remember it was in the hydrostat system.
/ Bobcat B250 problem PLEASE HELP #6
It seems 2 things went down at the same time. 1st had to change out a servo in the shift linkage and 2nd clean out the shift solenoid. a piece of metal was stuck holding it open or closed. Good Luck,
/ Bobcat B250 problem PLEASE HELP #7
Are these machines two speed, or forward / reverse shift solenoid?
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
Heavy Duty Plate Compactor (A64047)
Heavy Duty Plate...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
2022 INTERNATIONAL MV607 (A63569)
2022 INTERNATIONAL...
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
2016 CAT 308E2CR EXCAVATOR (A63569)
2016 CAT 308E2CR...
