Bobcat A220
/ Bobcat A220 #1
Bobcat Girl
Belleville, Michigan
A220
I need information on how to reset the handles in a Bobcat A220. Someone posted that the way to do this is to push both joysticks forward and then turn on the key and wait 30 seconds. This did not seem to work so apparently I'm doing something wrong. Right now it will only run in skid steer. It has all wheel drive and will not work. The time clock is broken so I do not know how many hours are on this machine. Any suggestions or recommendations would be greatly appreciated. I don't want to take it to a dealer because I can't afford it. I called ahead of time to a dealer and when he told me how much it would cost for them to analyze it and run tests he could have knocked me over so I'm trying to get some good advice from people who have figured out ways to correct this problem. I would appreciate all the help I can get. Thank you all.
/ Bobcat A220 #2
:welcome:
Welcome to the forum! I'm going to move this thread over to our Bobcat section to see if we can find you some help.
/ Bobcat A220 #3
Needs to be under Bobcat construction equipment to get proper help. This forum is for tractors.
/ Bobcat A220 #5
Bobcat AWS units will default to skid steer mode if there is a problem. When you select AWS mode and press the PTO button does the AWS switch blink? Is the warning light lit? :confused3:
/ Bobcat A220
Sorry for the delay in getting back with you. No to both questions. It stays in skid steer and I can't get it out. Thanks for your help.
/ Bobcat A220 #7
Are you hearing 3 beeps when you press the PTO button?:confused3:
/ Bobcat A220 #9
When you turn the key on do you hear 1 beep?? With the AWS mode switch in AWS,lap bar down and you press GREEN button only, Does the AWS switch light up solid green???
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 RAM 5500 4X2 S/A 14FT BOX TRUCK (A59910)
2019 RAM 5500 4X2...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
207282 (A52708)
207282 (A52708)
2018 MACK CXU (PINNACLE) (A63569)
2018 MACK CXU...
