Bobcat 873 Boggs down and dies
   / Bobcat 873 Boggs down and dies #1
jorswift
Upland, IN
JD955, MF1528, JD2240, JD 4300, Ford Jubilee
Hello all. Bought a 2001 Bobcat 873 machine. Had some issues when bought but I thought I fixed it all. I recently put a new fuel pick up tube, fuel filter and lift pump. Things work great under low rpm but once you give it some throttle it wants to bog down and stutter and even die at times. Is this a fuel issue? Thanks.
   / Bobcat 873 Boggs down and dies #2
Since the fuel system is where you made the changes, probably.
First thing to check is the pickup tube, is it longer than the one that came out, and does it have cutouts on the bottom edge so it can still get flow if it's on the bottom of the tank.
Also, if you replaced it because it was broken (common problem) the remnant can be rolling around on the bottom and partially blocking the new pickup.
The pick-up tube broke off into the tank. It was an aftermarket tube. It has the screen filter on the end of it. Also, used a cheap AMAZON fuel lift pump, so also thinking it could not be keeping correct pressure?
Ratchet Straps (A55852)
Ratchet Straps...
2001 Club Car Electric Cart (A55853)
2001 Club Car...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
