Bobcat 773G Hydraulic Issue
   / Bobcat 773G Hydraulic Issue #1
schifference
Ford
In preparation of expecting to use aux hydraulics I attempted to see if I turned them on and tried to activate them if they would appear to function. Machine boom and tilt was working as it was designed prior to me engaging auxiliary hydrauolics. Now boom and tilt do not work as designed and only work if Auxiliary hydraulics are activated in reverse. Please see video.
Any help/input is appreciated.
Thanks!
   / Bobcat 773G Hydraulic Issue #2
when you tried the aux hydraulics did you have anything connected to the couplers?
no
   / Bobcat 773G Hydraulic Issue #4
do you have anything you can attach, you could have dead head the spool and its stuck, not quite the same issue but if we run auxilary and not bleed wown its impossible to remove the quick connects, you could have pressure on the spool, stop motor, turn on ignition but not start motor, engage the aux circuit and move the switch back and forth, it may drain the pressure
Update. Presently I do not have an attachment to connect but please watch update and advise.
Thanks
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2019 BOBCAT T870 SKID STEER (A60429)
2019 BOBCAT T870...
2363 (A60432)
2363 (A60432)
159116 (A60430)
159116 (A60430)
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
