Bobcat 773 Warning lights come on then locks up.
   / Bobcat 773 Warning lights come on then locks up. #1
looneyk
Inman, SC
JD 820, JD 1026r TLB, Mistubishi D1650fd
My buddy has a bobcat 773, and he is able operate for a short time then the General Warning light, the Engine Oil Pressure Warning Light, Engine Coolant Temperature Warning, Hydraulic Oil Warning, and Hydraulic Temperature Warning lights come on and the whole machine locks up. He says that at that time his temp gauge shows low. He is sometimes able to fiddle with it enough and the temp gauge comes up and he hears a click under the machine and the lights go out and he is able to operate again. Any help would be appreciated.
   / Bobcat 773 Warning lights come on then locks up. #2
Did you find out what caused the chaos? Dealing with same mess now on 753.
   / Bobcat 773 Warning lights come on then locks up. #3
I hope someone else can help, since The OP hasn't been here for awhile:
   / Bobcat 773 Warning lights come on then locks up. #4
It sounds like your friend may be dealing with a sensor malfunction. Start by carefully checking the wiring, especially around the main harness and grounding areas. Next, inspect the fuses and the engine coolant temperature sensor, as defective sensors can trigger warnings and cause lock-ups. Also, check the hydraulic fluid levels and the main switch, as power loss and intermittent issues could be contributing factors in your Heavy Construction Equipment. If the problem persists, consider using a diagnostic tool or consulting an expert technician to identify the error and get the machine back in working order.
   / Bobcat 773 Warning lights come on then locks up. #5
Maybe this will help
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
Sterling AT (A55302)
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
8' SMALL FENCE POSTS (APPROX. 40-50 PC) (A54757)
8' SMALL FENCE...
1997 Ford LT9000 Truck, VIN # 1FDZU90T9VVA11840 (A54865)
1997 Ford LT9000...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
