Bobcat 435 mini x problems, need help
/ Bobcat 435 mini x problems, need help #1
Crystal Waterscapes
bobcat 435 fast track
I have a bobcat 435 mini exc fast track. I was working on it when I heard a snap or crack noise and the tracks quite turning. All the other hydraulics are still working. When I try to move forward or backward I get absolutely no response. I dont see any hydraulic leaks. My machine is stuck on a job site, I need to finish and get it out of there ASAP. Any ideas on what the possible problem and fix may be.
Thank you for your help
Robert
/ Bobcat 435 mini x problems, need help #2
If it is a "Fast Track" model, it has a belt driven hydrostatic pump. Sounds like the belt may have broke. All other hydraulics would work fine, they are run from pump directly on end of the engine. Hydrostatic pump is under the right side hood just behind the radiator.
2014 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2014 JAYCO...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
Skid Steer Logging Winch (A64047)
Skid Steer Logging...
2021 CAM p4EC16W102 16ft. 7000lb Utility Trailer (A64047)
2021 CAM...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
