Bobcat 334 Bucket Teeth
/ Bobcat 334 Bucket Teeth #1
Mainah334
The teeth on my excavator are worn quite bad and need to be replaced. I can see that there is some sort of pin holding them on, but am not quite sure how to remove it. Can I just drive this pin one way or another or does it screw in? Thanks in advance for any help.
/ Bobcat 334 Bucket Teeth #2
Most of the pins drive out.
/ Bobcat 334 Bucket Teeth #3
It is a roll pin, a rolled up tight coil of steel that was driven into place. I advise soiking them with penetrating rust oil, beating crap out of the tooth and driving them out with a sledge and punch from either direction. You may have to work it both ways. Drive the new pins in with a hammer and punch, and yes you must get new roll pins. Id advise doing it on the machine with the teeth at chest level. Wear ear protection as the bucket acts as a massive echo chamber. Did three changes on my old kx121 this way, good luck.
2023 KMC 3pt 6 Row Rolling Cultivator (A64119)
2023 KMC 3pt 6 Row...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2020 INTERNATIONAL LT625 SLEEPER (A59911)
2020 INTERNATIONAL...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
