Boat Lift Plans
   / Boat Lift Plans #1
Searchman
Hi!! I am new to this forum and am not sure if this is a proper post. I have a 20 ft boat in a private lake and want to construct a flotation style lift for the boat. The boat and motor weigh approximently 1500#. If any one on this forum has plans or has built one similar. Please respond. Thanks
   / Boat Lift Plans #3
I've seen some. Best best would be to visit someone that has one. They don't look that complicated. The ones I've seen utilize an air pump to add/remove water in pontoons. All the air in--it floats. Air out, it sinks and the boat floats. It would require a framework with some hinges that allow it to pivot.
Might be some online sources to look at too.
Hope this helps.
ron
TROY BILT PRESSURE WASHER (A51248)
TROY BILT PRESSURE...
2430 (A51248)
2430 (A51248)
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
