Bluetooth ear muffs
/ Bluetooth ear muffs #11
I have the 3M work tunes Bluetooth headphones. They have been working well and I haven’t experienced the issue that the OP is having.
Same here. I've had a pair for easily 15+ years but no bluetooth on that one. I replaced the ear pads last year.
Thank you! Didnt realize they just stick on. Found replacements for $10
I use the 3m Bluetooth headsets. When the padding wears out I replace with silicone pads, that are readily available.
/ Bluetooth ear muffs #13
I mow approx 7 acres at my property. With originally a loud Deere x758 and now with an equally loud Bad Boy Rogue zero-turn. I've used Bose Quiet Comfort 35 bluetooth wireless noise cancelling headset with great results. Reduces the overall mower noise and gives me great music audio. They were pretty expensive back when I first bought them but now they can regularly be had on sale for under $200. Still might 'pricey' if you're comparing to other simple noise reducing muffs but not at all bad for good quality audio headsets. To me they are worth their weight in gold for mowing and airplane trips.
/ Bluetooth ear muffs #14
If you have muffs you like, you can wear earbuds under them to get Bluetooth. A pair of noise canceling earbuds, worn under a good pair of attenuating earmuffs is highly effective.
Learned that courtesy of a couple of wildland helitack crew members. The hook into the intercom while in the aircraft. And occasionally someone will crank the master volume up. So, they wear the noise canceling earbuds inside their headphones to avoid the extremely loud sound hurting their ears. Plus, the earbuds knock out the rotor whack and turbine whine of the helicopters, while allowing the voices to come through.
/ Bluetooth ear muffs #15
Same here. 4 or 5 years on mine now.
/ Bluetooth ear muffs #16
I bought the 3M WorkTunes Connect with Gel Cushions back in 2022. They work great for listening to music and taking calls on the tractors or mower. They are exclusive to Amazon but are out of stock. Guess I should order replacement cushions before they are out of stock.
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
2019 Ford F-350 (A55973)
2019 Ford F-350...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A60352)
2017 Gravely...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
