Blue Smoke - choking
/ Blue Smoke - choking #1
marty
Mid West
Boomer 33D
Have a 20 Year Old Ford 4600 SU and last year it began choking out and then discharging blue exhaust under higher RPM and under load. The dealer replaced the fuel pump and it seamed to help a little.
The condition seems to be getting a little worse, so when I was replacing the fuel filter I noticed the injectors had never been changed. I replaced the injectors and the it still smokes badly.
Could this be bad valves or seats? Could a person replace the valves and seats from the top - under the valve cover? Other sugestion??
Thanks in advance!!
/ Blue Smoke - choking #2
Marty
I'M no expert but to me it sounds like very worn oil rings or even broken rings.
/ Blue Smoke - choking #3
yes, blue smoke usually means oil, so rings worn, broken or cracked. maybe vale seals but smoke due to seals usually clears up after intial puffs on starting. Do a compression check to find the offending cylinder.
I checked the tempature on each cylinder and they seam to be the same. The tractor does not use oil either and the breather seam to be fine. I did notice that it only starts to choke out at low ideal and at high RPM's.
There is no unusual smoke during moderate RPM's. I have to believe it is fuel related and the injector pump seems to be a high suspect.
/ Blue Smoke - choking #7
Make sure your thermostat is working and your engine is warming up. I threw a load to my tractor a little too early today and it started cutting out and blowing blue smoke just as you described. I let it warm up a little longer and the problem went away.
/ Blue Smoke - choking #8
See the post above concerning old fuel and fuel conditioners. Engine operating temp is critical, they weren't designed to putz around with the coolant temp below 180.
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
HARDEE GATOR TAIL PTO PUMP (A63291)
HARDEE GATOR TAIL...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
