Blower vs Plow
   / Blower vs Plow #1
Ed_C
Southwick, MA
Which would make more sense on a 30 HP Kubota B7800? A Blower or Plow attachment. Is driving backwards with the blower a problem? Though I can see the benefit of turning back around and having the loader right there in front ready to go.
I have just under 1000 ft of winding hilly paved driveway to clear. Narrow paved area but with space on the side to throw/push snow
   / Blower vs Plow #2
I haven't done either with my tractor, but I have plenty of experience shoveling the stuff. I would go for the blower - less of a mess near the driveway edges.
   / Blower vs Plow #3
I don't find any problems with my rear blower. I turn so that I am pretty much sitting sideways on the seat and barely have to turn my neck at all. The nice part is I can see directly in front of the blower, So I can see the large rock, tree, toy, small child, etc... and not hit it. I get to keep the loader on in case I want to scrape the driveway. My driveway is gravel so I leave the blower up a little so as not to pick up rocks and then scrape it with the loader if needed.
Also a good 5' blower is only about $1500-1800 whereas a plow alone will cost that without hydraulic hookups for angle. One thing I will add is a hydraulic chute turner so I don't have to get out everytime I want to adjust the exit of the snow. The heated cab with glass windows and wipers is a huge plus!
Here are some pictures:
http://www.tractorbynet.com/forums/attachments/owning-operating/66586d1166750594-plowing-loading-throwing-deep-snow-100_0602-1.jpg
http://www.tractorbynet.com/forums/attachments/kioti-owning-operating/48368d1134167351-snowblowing-ck20-785759-100_0603-1.jpg
http://i38.photobucket.com/albums/e139/4CE-FED/100_3007.jpg
The snowblower is so much cleaner than plowing.
Before and After
   / Blower vs Plow #4
Ed,
If you go for a blower you really need a cab....
I'm in Northeastern CT and have no problem with the front mounted plow and loader. The blower is cleaner, but you need the cab and a really big bag of sheerpins if the drive is gravel...
Regards,
Chris
   / Blower vs Plow
Thanks guys. Keep the ideas coming. A plow on my ATV has worked well on my shorter gravel driveway, but I'm moving to a place with a very long hilly driveway that thankfully is paved. i'm starting to see the benefits of a blower--especially having with quick access to the loader. but I'm still open right now.
Might just justify the cab ;-)
   / Blower vs Plow #6
Ed - If you search around this site, you should be able to read all you would ever want on this subject, as it's come up every winter.
In a nutshell, plows are faster but make bigger snow banks. Plows are at a disadvantage if you tend to get dumped on a lot with snow and wind resulting in a couple of feet or more to try to move. Rear blowers are half the price of front ones, but you have to turn around. Some folks don't mind this, others get sore necks or backs, but it is nice to be able to keep the loader on. On some tractors, reverse gear may be too fast to use without a lot of clutch work. With a blower, a cab is a very good thing.
I bit the bullet and bought a front blower, cab, and heater. It's been worth every penny -- to me, anyway.
Tom
P.S. The picture is obviously B.C. -- before cab. Also, I have a gravel driveway, keep my blower low, yet rarely replace a shearpin.
   / Blower vs Plow #7
Blower
The B7800 is on the lighter side (1,800#). My old TC18 (1,400#) wouldn't plow uphill, but would blow snow uphill - rear blower.
My new B3030 came with a 63" front blower:cool: (but no cab):eek: .
   / Blower vs Plow #8
If snow is under 3' I'd say plow wins hands down in terms of efficiency. Plus you can go as fast as the tractor will go if you stay on top of it. All done in 15 minutes. However, if you run out of room to stash the snow, the blower will toss it farther. As for rear control, its awful Once you sample going foreward, there's no going back...
Plow tractor ought to have 4WD and weights plus Left/Right brake steer. I run a pick up truck plow suspended right in front tof the front weight bar. This keeps the plow close to the steered wheels and resists push off forces.
When a storm comes up, I park the tractor in the barn: plow facing out. Get her going and I'm all done both directions before the motor warms up. The guys with rear anything have only reverse speeds at their disposal.
   / Blower vs Plow #9
TMcD_in_MI said:
Ed - In a nutshell, plows are faster but make bigger snow banks. Plows are at a disadvantage if you tend to get dumped on a lot with snow and wind resulting in a couple of feet or more to try to move. Rear blowers are half the price of front ones, but you have to turn around. Some folks don't mind this, others get sore necks or backs, but it is nice to be able to keep the loader on. On some tractors, reverse gear may be too fast to use without a lot of clutch work. With a blower, a cab is a very good thing.
In my opinion, Tom sums it up nicely. I have a B7800 with LA402 FEL and an old 72" rear blower. The blower is really too wide for the tractor (awkward to move around - no problem whatsoever powering it), but I already had it when I got the B7800, so the price was right. With the HST you can infinitely adjust your ground speed to match what the tractor & blower can handle. Also having the FEL on the other end adds a lot of flexibility. Maybe I'm getting old:eek: and spoiled:cool: , but I consider a heated cab and power chute rotation to be absolutely necessary.
   / Blower vs Plow #10
How about the best of both worlds. A plow on the loader and a blower on the rear. I like it a lot.
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
Irrigation Pump with John Deere 4045 Engine (A52128)
Irrigation Pump...
UNUSED FUTURE EXCAVATOR RIPPER (A51244)
UNUSED FUTURE...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A52128)
Marliss Industries...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
72In FEL HD Round Back Bucket (A52128)
72In FEL HD Round...
