Blower too big???
   / Blower too big??? #1
mothgraphics
Greenwich, NY (40 NW of Albany, NY - 10 miles from
Kubota 7200D 4wd
7100
Hey Folks, new here.
I have a Kubota B7200 4wd tractor with 18HP / 12HP rear (Live) PTO.
I just purchased a Blizzard 64" snowblower that was only used twice, so I thought I was getting a good deal. It was used on a slightly larger tractor, but with a bucket .
I hooked it up yesterday, and it's apparent that this thing it just too big / heavy duty for my tractor. If I try and go forward, I spin (turf tires), and if I lift the blower up, the front tires come off the ground nearly, so I can't steer.
Is this a job for chains and front weights, or should I seek out a smaller blower? The second question is if it's the latter, anyone looking for a nice blower???
Thanks for any help. Winters Here!
   / Blower too big??? #3
I do not have a snowblower--so only opinions here! The weight may not be as much of an issue as the PTO HP required. The blizzard site says it weighs around 480 lbs but requires 20-35 PTO HP. How did it spin when you cranked it up? I would think some weights on front would help--it seems that most folks who have blowers do not need chains as the blowers clear their path for them.
   / Blower too big???
It seemed to spin fine, but my testing was limited. I drove backwards a bit, and it seemd to shoot the wet/ heavy snow we got pretty nicely, but being a live PTO, I have concerns about it clogging when I put the clutch in to stop. It does keep spinning nicely in neurtal though.
ow...20-30hp...that would explain it. Better stick it on ebay or Craig's List. Maybe someone here has a suggestion for another brand of decent blower for this size tractor around $1500? Maybe a trade on this site is an idea?
   / Blower too big??? #5
Yes if you have a FEL or front weights that might get you moving a little easier.. If you have hills or slopes chains will help from what I understand also
   / Blower too big??? #6
If it was April, I would think this is a joke.
Yes, it's too big for your tractor.
About 30" too big.
   / Blower too big???
About 30" too big.
Well, if that's the case, I'm introuble. Do they even make 36" snowblowers?
Christ, I had a 2WD case previously with a fron mount blower that was 50" wide, and it worked great. Only figured theis larger Kubota with 4WD would do the job easier. It is a seriously heavy duty blower. Maybe a lighter weight 48" would work?
   / Blower too big??? #9
I would experiment with some chains on the rear tires and hang some weight on the front and see what you can do. Now the disclaimer, I've never moved a cuft of snow with a blower so what do I know. I just wouldn't giveup without testing some ideas first. bjr
   / Blower too big??? #10
Agree--I would do what I could to give it a serious test first. If you fill in your profile so folks know where you are--you may get a PM with an offer!
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A52141)
2015 INTERNATIONAL...
2004 Mercedes E320 Sedan (A50324)
2004 Mercedes E320...
2021 John Deere XUV835M Gator (A50514)
2021 John Deere...
2017 Kia Optima LX Sedan (A50324)
2017 Kia Optima LX...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
