Block heater
/ Block heater #2
Internal or external?
/ Block heater #4
Years ago, I had a 68 Plymouth which had an external propane engine heater. As I recall it was built by Phillips Industries in Minneapolis.
There was a small propane tank in the trunk, a heating tank inserted into the lower radiator hose, which was fired by a glow plug. No extension cords needed, it used the 12 volts from the battery to fire off using a glow plug, then would run with no electric usage. The on off controls were also under the hood.
/ Block heater #5
Most efficient is frost plug block heater since all the heat goes directly into the block. Also usually lowest wattage so uses the least electricity
2015 Peterbilt 320 Roll-Off Truck (A66736)
2015 Peterbilt 320...
MF GC2300 fel replaced
ALLMAND  MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
THE MACHINE CO. THAWZALL H250 HEATER TRAILER (INOPERABLE) (A67714)
THE MACHINE CO...
2019 FOREST RIVER WILDWOOD (A67714)
2019 FOREST RIVER...
