Block Heater
/ Block Heater #1
bikerzing
Tomah, WI
1970 John Deere 1020
If I were to purchase a magnetic block heater, where would be the best place to locate it? Oil pan? Have you had any success with these? I considered one for the frost plug, but I was worried it wouldn't fit. These seem pretty easy and possibly have other uses.
/ Block Heater #2
Personally I tried this and it didn't work very well. The regular factor type block heater that goes into the core plug is a better way to go. They are generally easy to install and work well to heat the cooling jacket and that makes for easy starts. A lower rad hose heater would be a distant second choice.
/ Block Heater
Thanks Jerry. Forgive my ignorance, but what and where is the core plug?
/ Block Heater #4
I could never figure out why these things were so expensive. Otherwise I would have a couple on hand. I guess it would be nice to have one on the oil pan, and a block heater.
I should have one on my loader hydraulic tank.
/ Block Heater #5
When my block heater failed I tried the magnetic one that I had purchased at a yard sale.
After 24 hrs the tractor still would not fire up.
I had better luck heating the oil pan with my plumbers torch.
My 2 cents is measure carefully the frost plug opening and buy a proper block heater.
If U are in colder climates most auto parts will have listings.
Installation is really easy and takes less than 1/2 hr.
Simply drive a screwdriver into the frost plug and pry out the disc. Grease the O ring on the plug heater and tighten the plug in place.
Helps to drain the coolant first naturally unless you plan to replace it. Actually you only need to drain about half as frost plugs are about 1/2 way up the engine block.
/ Block Heater #6
Magnetic are useless , Get a proper one .
/ Block Heater
Thanks for the information. You make this sound very easy and I think I will take this approach. One problem I have had is actually locating the frost plug. Maybe I am looking on the wrong side of the block? All engines have these right? And this is threaded?
/ Block Heater #8
If it is a 1020, there ain't no frost plug
Need locate the lowest coolant port or drain on the left side of tbe block. Then locate the highest coolant port on the engine , on the engine side of the thermostat.
Install an external tank heater.
Do not run the hot line downhill and do not route the cold line uphill.
1500watts will heat the engine from stone cold to warm in Less than an hour.
/ Block Heater #9
The best location is right on the store shelf.
/ Block Heater #10
Core plugs are used to remove the sand from the block casting mold and then a pressed in steel plug ( kinda' looks like a bottle cap) is inserted to retain the coolant in the water jacket.You remove this with a punch and the block heater fits in the hole.
/ Block Heater #12
Yep, the magnetic type is pretty much a waste of time and money. I let someone talk me into buying on many years ago, never was able to see any benefit at all from using it, even if left on all night. Haven't used it since, stuck it on the end of my toolbox about 6 years ago and it's hasn't been off since.
/ Block Heater #13
I find that my lower rad hose heater works great. Of course I also have a block and battery heater...about 1000watts total
/ Block Heater #14
smiling..... You beat me to it. I bought one for my 3020 years ago, used it once, put it on the shelf and it is still there.
/ Block Heater #16
So why does the mag heater work on the log splitter and not on a tractor?
I used one on the oil pan of a two cylinder air cooled Diesel and it seemed to work for me. I mean, the head was warm, and not hot as it might be on a liquid cooled engine with a block heater. But, if you have glow plugs and a healthy engine, that should be good enough.
/ Block Heater #17
The KATZ company has made freeze plug heaters since time began. I have put them in my cars before. I have one dealer installed on my Massey. One thing I remember about those is that you need to be sure to locate them in the plug they tell you to use. Otherwise sometimes it makes them not fit due to cylinder clearance and such so be careful. The one I have now works great . Starts right up any temp
/ Block Heater #18
It's just that the block or inline heaters work so much better. Air cooled is just a little different.
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
INOP Kodiak Four-Wheeler (A65579)
INOP Kodiak...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
INOP/NON-RUNING Genie GS3232 Scissor Lift (A65579)
INOP/NON-RUNING...
2022 EZ-GO ELITE...
