block heater
   / block heater #11
..I was more or less referrin' to an oilpan heater
Thanks for the information.:thumbsup:
Best wishes for a full and complete recovery.:thumbsup::thumbsup:
   / block heater #13
Not @ all.....I'm usin' a circulating external type that I picked up @ Nappa more than 3 years ago....it's exactly what I needed....I got it mounted underneath the front section.....about the only place I could mount it....Iseki's don't have much room to install anything.....Ampa
   / block heater
Ampa, Hope you are feeling better. I have one of those tank type recirculating block heaters that would work perfect using the block drain port for the inlet and the temp. sensor port for the outlet. But where can I pick up engine temp? You mentioned using a thermometer jacket. What is that and where did you put it?
   / block heater #15
That's where the thermostat goes....housing is already on your tractor I assume...should have the thermostat gauge outlet hooked into it.....check it and see what I'm meanin' here.............. Ampa
   / block heater
My temperature gauge sensor goes onto a port in the block near the thermostat housing. Does your tractor have another port in that area that you plumbed your block heater into?
   / block heater #17
I'm just thinkin' out loud here ....I'm gettin' old and forgetfull....but I think my old gauge was wired into the thermostat housing....it's been more than 3 years since I installed the blockheater.....I think you could connect it off the engine block if you wanted.........Ampa
   / block heater #18
I bought 2 different Frost Plug heaters for my Iseki TA247. Both had instructions as to which cyllinder they were to be fitted in. Wrong. Neither one fit. I ended up with a lower radiator hose heater that works good only after several hours of being pluged in.
   / block heater
I just looked over the engine block again. There is a soft plug on the back of the head. I will measure the soft plug and make sure I can find a replacement. Then I will try to braze a fitting to the soft plug that will hook up my block heater there. Then I can leave my temp gauge sender where it belongs. And the outlet would be on the other end of the block affording good circulation of the heated water. Ampa hope you are getting better. Is yours one of the two cylinder tractors?
   / block heater #20
I have the 3 cylinder......Ampa
2025 AGT H15R Mini-Excavator with Dozer Blade & Pilot Controls  (New/Unused) (A59225)
2025 AGT H15R...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
1792 (A58375)
1792 (A58375)
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
Linde E25C 5,000 lb Electric Forklift  Cushioned 4-Wheel, Indoor/Outdoor Use **Needs Batteries** (A59225)
Linde E25C 5,000...
