block heater
/ block heater #1
bobcat7532010
have a bobcat 753 put in a block heater and it leaks what can I do next?
/ block heater #2
Drain coolant. Remove block heater. check for pinched, broken seals/rough edges. Repair and replace insuring it is tightened to proper specifications.:D
/ block heater
would it be wise to put RVT seal on it prior to fitting it
/ block heater #5
I use Loctite 515 gasket eliminator to seal/lubricate block heater o-rings. It's kind of an odd use for that product, but I have NEVER had one leak, and some have been installed for 10 years. Making sure the block bore is absolutely clean and smooth is a requirement.
/ block heater
Tired the gasket elimintor and it worked great. All put back together and back to pushing snow again.:)
2022 EZ-GO ELITE...
Dodge Charger (A56859)
SET OF (3) CHEMICAL HOSE REELS (A63569)
SET OF (3)...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
2009 MACK GU713 DAY CAB (A63569)
2009 MACK GU713...
2016 FREIGHTLINER CASCADIA (A63569)
2016 FREIGHTLINER...
