block heater
/ block heater #1
bobcat7532010
have a bobcat 753 put in a block heater and it leaks what can I do next?
/ block heater #2
Drain coolant. Remove block heater. check for pinched, broken seals/rough edges. Repair and replace insuring it is tightened to proper specifications.:D
/ block heater
would it be wise to put RVT seal on it prior to fitting it
/ block heater #5
I use Loctite 515 gasket eliminator to seal/lubricate block heater o-rings. It's kind of an odd use for that product, but I have NEVER had one leak, and some have been installed for 10 years. Making sure the block bore is absolutely clean and smooth is a requirement.
/ block heater
Tired the gasket elimintor and it worked great. All put back together and back to pushing snow again.:)
IREV HIgh End Electric Scooter (A60463)
IREV HIgh End...
TRACTOR SHEDDER (A60736)
TRACTOR SHEDDER...
2012 FORD F-250 (INOPERABLE) (A60736)
2012 FORD F-250...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
