block heater
   / block heater #1
bobcat7532010
have a bobcat 753 put in a block heater and it leaks what can I do next?
   / block heater #2
Drain coolant. Remove block heater. check for pinched, broken seals/rough edges. Repair and replace insuring it is tightened to proper specifications.:D
   / block heater
would it be wise to put RVT seal on it prior to fitting it
   / block heater #5
I use Loctite 515 gasket eliminator to seal/lubricate block heater o-rings. It's kind of an odd use for that product, but I have NEVER had one leak, and some have been installed for 10 years. Making sure the block bore is absolutely clean and smooth is a requirement.
   / block heater
Tired the gasket elimintor and it worked great. All put back together and back to pushing snow again.:)
2008 New Holland B110 MFWD Loader Backhoe (A53472)
2008 New Holland...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Airco Tig Welder (A51691)
Airco Tig Welder...
