Block heater or in line coolant heater for my BX2230
   / Block heater or in line coolant heater for my BX2230 #1
joesco
I'm not overly impressed with the glow plug set-up in my BX2230. This morning, with temps in the 40's, I had to glow plug it twice to start him.
I've searched and it appears I can only use an in-line coolant heater, but I prefer a block heater.
Has anyone installed a block heater in this model, if so can you provide a part number and freeze plug location.
Thanks very much!
   / Block heater or in line coolant heater for my BX2230 #2
I had one installed a year ago. I was worried about leaks, so I hauled it to the shop. Took about 20 minutes. I don't have a part number though. But I love it. When it was below 0, my garage was mid 20's. I'd open the hood and there was a wave of warm air off the block after an hour.
Edit: Oh yeah, it was installed on the left side, somewhere between 1st and 2nd cylinder if I recall. I'll have a look when I get home.
Thanks and it was a block heater in BX2230?
   / Block heater or in line coolant heater for my BX2230 #4
Quick search says that the part number for the BX2230 block heater is 70000-00771. Looks like it has 25mm or 1 inch threads per the pictures.
NOTE: I do NOT know first hand that this fits your tractor though.
Thanks, found it. $ 39.99.with free shipping from a Kubota parts company on the auction site.
It's a 7000-73274
KUBOTA :*This Heater Fits All tractors*which*takes 1" NPT Thread in Block*
Kubota B SERIES Compact Tractor:*B1550, B1550D, B1700, B1750, B20, B2100, B2150, B2320, B2400, B26, B2620, B3030, B5200D, B6200, B7200, B7500, B7510DN, B7510HSD, B8200, B8200HST, B9200, B9200HST
Kubota BX SERIES Sub Compact Tractor:*BX22, BX23
Kubota FZ SERIES Commercial Front Mower:*FZ2400
Kubota G SERIES Garden Tractor:*G3200, G4200, G6200
Kubota L SERIES Tractor:*L305
Kubota L SERIES Tractor:*M105S
   / Block heater or in line coolant heater for my BX2230 #6
Put this one in my BX2230 Kubota #70000-00771 says they have 11 in stock .
The newer Kubota #70000-00297 says in description NOT FOR BX2230. Not sure what changes were made but the BX2230 2350, 2370,2380 are all using the D902 engine. They are now saying to use the one in the radiator hose which I do not like heating air.
Only real difference is the old one is one piece and the new one screws into an adapter and does not go into the block the proper distance
I say get one of the old Kubota #70000-00771 at Messicks if you can.
Kubota: Block Heater Kit, Part # 7-771
David
   / Block heater or in line coolant heater for my BX2230 #7
In line heaters fit the bottom radiator hoze so they are immersed.
David
Thanks folks!
   / Block heater or in line coolant heater for my BX2230 #9
Thanks folks!
I looked at mine tonight and unless I take off the cowling, it is buried. I'm remembering the mechanic tapped mine in using a large socket. But I could be wrong.
   / Block heater or in line coolant heater for my BX2230 #10
Watch out removing the freeze plug. There was a thread last year about someone who drilled out the plug and put a whole into a cylinder. My 3350 has a screw in heater and when it’s below zero it starts right up with about an hour of heat. A thought about your hard start in mild weather....have you used power service on your fuel? You might have water that is causing hard starting and power service or something like that might help.
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
JOHN DEERE 54D LOT NUMBER 162 (A53084)
JOHN DEERE 54D LOT...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
JOHN DEERE Z997R LOT NUMBER 242 (A53084)
JOHN DEERE Z997R...
