Block Heater on M7060HDC12
   / Block Heater on M7060HDC12 #1
Walden, NY
970 John Deere
Do they all come standard with a block heater or is this an option?
   / Block Heater on M7060HDC12 #2
I have a 3130 and I put my own in from a Kubota dealer..
Thanks John,
I'll have to source one once the machine arrives...if I pull the trigger tomorrow??
   / Block Heater on M7060HDC12 #4
Block heater is option.
If you want to put it in yourself, don't. Potential for damaging the block if you do it wrong so search for a similar model Kubota that required a partial engine rebuild on a nearly new tractor.
EDIT--Let me add that you may not need one. My M7040 starts just fine at 3 degrees and I have owned others when I lived in Maine that I started at colder temps. Both tractors were in barn but no heat and no block heater. Block heaters are nice so just toss this in your thought process.
   / Block Heater on M7060HDC12 #5
There are models you put in the lower radiator hose. Pretty easy to install.
Thanks for the tip. Ill be parking under a pavilion, so it will be exposed to the wind until I close the sides in. Its been pretty cold here in NY this week and got me thinking. I thought it would be standard equipment, but I figured I'd ask before making that assumption.
   / Block Heater on M7060HDC12 #7
Let me further add that my Kubotas started at around zero, as mentioned three posts earlier, and did it on dino oil. They could wait to start with synthetic.
Yes, I guess I would want a heater but I'm not sure the world would end if you didn't. If you're just using to plow snow, it's usually warmer when it snows.
AMADAS 2100 LOT NUMBER 255 (A53084)
AMADAS 2100 LOT...
2008 Ford F-250 (A53472)
2008 Ford F-250...
2013 MACK CXU (A52472)
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
SKIDPRO  SKID STEER GRAPPLE (A52472)
SKIDPRO SKID...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
