Block Heater on M7060HDC12
/ Block Heater on M7060HDC12 #1
Walden, NY
970 John Deere
Do they all come standard with a block heater or is this an option?
/ Block Heater on M7060HDC12 #2
I have a 3130 and I put my own in from a Kubota dealer..
Thanks John,
I'll have to source one once the machine arrives...if I pull the trigger tomorrow??
/ Block Heater on M7060HDC12 #4
Block heater is option.
If you want to put it in yourself, don't. Potential for damaging the block if you do it wrong so search for a similar model Kubota that required a partial engine rebuild on a nearly new tractor.
EDIT--Let me add that you may not need one. My M7040 starts just fine at 3 degrees and I have owned others when I lived in Maine that I started at colder temps. Both tractors were in barn but no heat and no block heater. Block heaters are nice so just toss this in your thought process.
/ Block Heater on M7060HDC12 #5
There are models you put in the lower radiator hose. Pretty easy to install.
Thanks for the tip. Ill be parking under a pavilion, so it will be exposed to the wind until I close the sides in. Its been pretty cold here in NY this week and got me thinking. I thought it would be standard equipment, but I figured I'd ask before making that assumption.
/ Block Heater on M7060HDC12 #7
Let me further add that my Kubotas started at around zero, as mentioned three posts earlier, and did it on dino oil. They could wait to start with synthetic.
Yes, I guess I would want a heater but I'm not sure the world would end if you didn't. If you're just using to plow snow, it's usually warmer when it snows.
