Block Heater Location on M4500
   / Block Heater Location on M4500 #1
Jerry/MT
Elite Member
North Idaho-The Palouse
New Holland TD95D, Ford 4610 & Kubota M4500
Our M4500 has a rad hose heater on it and it's shot. I prefer a block heater to hose heaters but at first glance I don't see where it is to be installed. I have installed them in other tractors but I don't see a location for the S2600-A engine. However Kubota offers them for this model. they are 3/4" NPT and some engines use a 3/4" to 1" NPT bushing to adapt them.
Do any of you guys know where they are installed?
Turns out the block heater goes in a core plug hole on the LH side of the block. A special NPT threaded tapered SS bushing is driven into the core plug hole and the block heater screws into that.
   / Block Heater Location on M4500 #4
I clip one of those painters lights with a 60 watt bulb to the oil pan...
...thin/warm oil will insure you get enough 'spin' to start up when it's cold.
An incandescent bulb generates heat.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Wolverine Quick Attach Utility Hitch Adapter (A50514)
Wolverine Quick...
Backhoe Bucket (A50515)
Backhoe Bucket...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
Smoke Daddy Portable Grill (A50515)
Smoke Daddy...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
