Block heater location L 2501
   / Block heater location L 2501 #1
24mph
Shiawassee County ,MI
John Deere MT, Kubota 2501
I purchased a screw-in block heater manufactured by Kats for a 2016 L2501 Kubota. I cannot figure out where it goes. Am I blind or is the 2016 engine redesigned and Kats hasn't realized it yet ?
   / Block heater location L 2501 #2
I don't know for sure so take this with a gain of salt. These standard L's uses the frost plugs. You remove one and insert the threaded part... DO NOT drill it out, there's a thread about someone having to re-build his block.
Does it look like this:
   / Block heater location L 2501 #3
Teg is correct. The element is a soft plug type application. Order the part from your Kubota dealer.
I didn't get the large replacement for the frost plug, only the threaded element. Will check with the supplier. I didn't buy it from a Kubota dealer.
   / Block heater location L 2501 #5
The cylinder walls are very close to the softplugs so the nipple is required for the element to have room for install.
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2018 TAKEUCHI TL12V-2 SKID STEER (A51246)
2018 TAKEUCHI...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52748)
2022 JCB 3TS-8T...
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
Guard Rail Joints (A51692)
Guard Rail Joints...
