Block Heater Issue
/ Block Heater Issue #1
Becharpa
Bridgton, maine
Mahindra 2015HST
I accidentally had a piece of my screw driver fall into block heater hole while I was taking out the freeze plug? Any thoughts? Can I flush it out? Tried magnet can't find it? Will this harm my engine? Your help is appreciated.
/ Block Heater Issue #2
Would not believe any harm can happen as it is in the water jacket area and only water/coolant flows there, mind you if it were to block a very tight water passage area then a 'hot spot' could occur.
Personally I would not worry.
The only thing your magnet will find is the engine block and ignore the bit.
I
/ Block Heater Issue #3
I had the freeze plug fall in mine,,several hundred hours ago,couldn't get out and no problems.
/ Block Heater Issue #4
A long shot but it might be worth while to take a look with a small inspection mirror/flashlight and or try a set of mechanical fingers.
I wouldn't think the velocity of the coolant in the lower block will be high enough to lift it up anywhere disastrous.
/ Block Heater Issue #5
The radiator will act as a fliter to stop it from circulating!! :laughing:
Don't worry about it,,,, :confused2:
2008 MACK GRANITE KILL TRUCK AND TRAILER (A65643)
2008 MACK GRANITE...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
90in. Work Bench (A65640)
90in. Work Bench...
NEW 14' RS GODWIN BODY (A62613)
NEW 14' RS GODWIN...
Mitas Tire (A65640)
Mitas Tire (A65640)
2018 DODGE RAM 2500 (A65643)
2018 DODGE RAM...
