Block heater install help
/ Block heater install help #1
chliansh
So far this has been a nigtmare, first the frost plug fell inside the block before I could catch it (I did recover it after some hard work+bad words)now I find that i do not even have the clearance I need to even install the heater element in the flange. Can anyone give me some suggestions or tell me what part that is in my way? Oil came out when I removed the black bolt? (see pic)
/ Block heater install help #2
What tractor is this?
It looks like you are on the left side of the engine.
On my 2210, the block heater went in the right side......
4010, it is the right side that I am working on right above the oil filter. I belive the part I am looking at (the one thats in the way)is the governer. The dealer shows a part that wil replace the cover with a flat one, see this site web page
But what happens to the long bolt?
Can anyone tell me what will happen when I replace the bolt\cover (governor?) with the plate only for clearance issues with the frost plug?
/ Block heater install help #5
chliansh,
I do not know what the difference is between the location of the frost plug, and installation of the block heater on a 2210 vs. 4010. However, the webpage/instructions and pictures you posted are for a 2210. Are you sure your dealer gave you the correct heater kit? Perhaps the motor/layout is the same but, if you have a part that is interfering with the new heater, my guess is wrong kit, wrong instructions...??? I've installed block heaters on numerous vehicles (cars, trucks, ...). It has always been a relatively straight forward process if I had the correct kit. I'd re-check with the dealer and with J.D. service if needed to be sure you're not fighting a no-win battle with the wrong part.
Good luck,
Tom
/ Block heater install help #6
chliansh,
I just checked J.D.'s 4010 parts ("Block Heater" (Optional)) and it appears you have the right part number. Guess I don't know why you run into an obstruction. Hope some one else can provide guidance.
Good luck,
Tom
/ Block heater install help #7
I have installed block heater in 2210. Here's the web page
Even on the 2210 you must install the heater element into the adapter then install on engine. You may or may not need the governor case cover. On 2210 their's no need for it. From your picture I can not tell the distance from the cover to block heater. Take out the adapter and install the heater element into the adapter and then see if you can install it on engine. I hope this help a little.
I need the cover for sure(no space for the heater ). I just need to know what happens to the parts I elliminate with the new cover. My dealer is clueless.
/ Block heater install help #9
cliansh,
Let me know if you're still stumped. I have tomorrow (Thurs.) off and will be near my dealer. Up here, they install block heaters on most every CUT and full size they sell, so I'm pretty sure they'd have run into the issue and know the solution.
Tom
Still stuck, I did talk the dealer into contacting JD directly but they said it will take a couple of days to hear back. This whole thing is way more complicated then it should be.
/ Block heater install help #11
cliansh,
Still trying to help figure this out. Looking at J.D.'s 4010 parts site for "Block Heater (Optional)", there are some significantly different part numbers than the 2210 Block Heater parts you attached.
JD 4010 Block Heater
I have a call in to my dealer's mechanic but am waiting for a call back.
I took a look at mine on the 4115 and don't think it is very helpful as it is located on the opposite side of the motor (right side from view, standing in front of tractor, looking toward motor and seat. However, I did look at the left side and found there appears to be another plug, just above the fuel filter (looks alot like your pic). I am attaching pic's of my placement (opposite side from fuel filter). Is it possible you had two options and the one you chose (ala 2210) is the wrong side for a 4010?
Tom
/ Block heater install help #12
2nd pic of my block heater's location (may be of no help).
Sorry the JD link seems to only go tho their parts locator, not to the actual 4010 block heater parts page I tried to link.
Still waiting on call back from local JD mechanic.
Tom
/ Block heater install help #13
cliansh,
Just talked to my mechanic. Here's his take on what is needed:
AM882530 Kit (Screws, Gasket & Adapter) [believe you have this]
AR87167 Kit (Heater & Power Cord) [Think you said you also have this]
M89154 (no description I could find, anywhere on JD website(s))
805705 (no description I could find, anywhere on JD wbsite(s))
His description is that the "adapter" should set the element back far enough from the interior parts to allow proper clearance.
Good luck...wish I could have found descriptions/pictures of those other two parts.
Tom
Thanks trlong,
My dealer did get back to me and said the official instructions on the 4010 block heater install "discard the extra parts that are no longer needed" Its a a part of the injector pump that is supposedly not needed? Still seems odd to me but I guess I have to go that route.
/ Block heater install help #15
cliansh,
Great. Let us know how it works out. This thread could be a valuable time saver for others installing the heater on a 4010 and scratching their heads as to why it doesn't fit, as is. Does seem odd though, as you say, to have to discard a part that is "no longer needed".
Tom
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
KUBOTA BT1973 - 17 1/2" EXCAVATOR BUCKET (A64280)
KUBOTA BT1973 - 17...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-150...
36" X 12' ADS DRAINAGE PIPE (A64281)
36" X 12' ADS...
