block heater freeze plug instead of JD kit?
   / block heater freeze plug instead of JD kit? #1
v8only
Mb
1988 John Deere 755
Its that time of the year and im going to be adding a block heater.
I see that the JD block heater requires a adapter kit but has anyone installed a regular frost plug block heater? i was thinking about knocking out the frost plug measuring the diameter and buying a block heater for $13.00 vs $80.00 from JD.
   / block heater freeze plug instead of JD kit? #2
Some of the block heaters need that adaptor sleeve to provide clearance from cylinder walls, without it, there is not enough space for the heater element. I am sure JD probably sources it from Kats or spme other maker, so if you can find that out you can probably buy cheaper.
great thanks, i was able to cross reference the JD part numbers and found the part numbers for aftermarket that come complete with the adapter/spacer kit.
   / block heater freeze plug instead of JD kit? #5
Zerostart #3100003. Available at O'Reilly's
On second thought... I'm not sure if the 755 uses that one or not.
   / block heater freeze plug instead of JD kit? #6
Would it be possible to share the cross referenced information and whether you had any trouble with the parts? or tips for install? Thank you!
199049 (A51243)
199049 (A51243)
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
Adams 5T High Clearance Fertilizer Spreader (A53473)
Adams 5T High...
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
