block heater freeze plug instead of JD kit?
   / block heater freeze plug instead of JD kit? #1
v8only
Mb
1988 John Deere 755
Its that time of the year and im going to be adding a block heater.
I see that the JD block heater requires a adapter kit but has anyone installed a regular frost plug block heater? i was thinking about knocking out the frost plug measuring the diameter and buying a block heater for $13.00 vs $80.00 from JD.
   / block heater freeze plug instead of JD kit? #2
Some of the block heaters need that adaptor sleeve to provide clearance from cylinder walls, without it, there is not enough space for the heater element. I am sure JD probably sources it from Kats or spme other maker, so if you can find that out you can probably buy cheaper.
great thanks, i was able to cross reference the JD part numbers and found the part numbers for aftermarket that come complete with the adapter/spacer kit.
   / block heater freeze plug instead of JD kit? #5
Zerostart #3100003. Available at O'Reilly's
On second thought... I'm not sure if the 755 uses that one or not.
   / block heater freeze plug instead of JD kit? #6
Would it be possible to share the cross referenced information and whether you had any trouble with the parts? or tips for install? Thank you!
1995 Ford F-700 Flatbed Truck (A53117)
1995 Ford F-700...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
John Dozer JD650 (A51691)
John Dozer JD650...
2 Cork Boards (A51695)
2020 CATERPILLAR 299D3XE SKID STEER (A52705)
2020 CATERPILLAR...
