block heater freeze plug instead of JD kit?
   / block heater freeze plug instead of JD kit? #1
v8only
Mb
1988 John Deere 755
Its that time of the year and im going to be adding a block heater.
I see that the JD block heater requires a adapter kit but has anyone installed a regular frost plug block heater? i was thinking about knocking out the frost plug measuring the diameter and buying a block heater for $13.00 vs $80.00 from JD.
   / block heater freeze plug instead of JD kit? #2
Some of the block heaters need that adaptor sleeve to provide clearance from cylinder walls, without it, there is not enough space for the heater element. I am sure JD probably sources it from Kats or spme other maker, so if you can find that out you can probably buy cheaper.
great thanks, i was able to cross reference the JD part numbers and found the part numbers for aftermarket that come complete with the adapter/spacer kit.
   / block heater freeze plug instead of JD kit? #5
Zerostart #3100003. Available at O'Reilly's
On second thought... I'm not sure if the 755 uses that one or not.
   / block heater freeze plug instead of JD kit? #6
Would it be possible to share the cross referenced information and whether you had any trouble with the parts? or tips for install? Thank you!
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
DESK (A53843)
DESK (A53843)
