Block Heater Deere 110TLB JD 110 TLB
   / Block Heater Deere 110TLB JD 110 TLB #11
the plug protector is 360-0012 ; it was just over two dollars, I know it was not necessary, but again it was only two dollars.
   / Block Heater Deere 110TLB JD 110 TLB #12
Just to confirm these are for a JD110 TLB? I cant find either part number on ZeroStart's webpage under "John Deere".
   / Block Heater Deere 110TLB JD 110 TLB #13
Here is what I did. I googled the normal/plain deere drain plug until I found an application that actually listed the size of the plug (1/2 npt if I recall) then I ordered the shortest& lowest wattage heater in that size. I have less than an hour on since the install, but as far as I know, no issues....
   / Block Heater Deere 110TLB JD 110 TLB #14
the one I ordered was 860-9624, it is 150w, there are higher wattage ones available, but without knowing exactly what deere uses, I felt better to be safe and use the lowest wattage unit.
ar87167; 120 vac, 400 watt, 36 ohm's resistance, 3.33 amps.
   / Block Heater Deere 110TLB JD 110 TLB #16
I'm not always certain that the time you waste "chasing a few dollars" is really saving much... Time or money.
I put the OEM heaters in both tranny and block. Easy peazy. And no leaks, etc.
AKfish
   / Block Heater Deere 110TLB JD 110 TLB #17
Well the ZeroStart block and tranny heater came out to $130 shipped. The Deere heaters come out to $240 (canadian). I'll take the $110 and thank all of you guys for the part numbers.
   / Block Heater Deere 110TLB JD 110 TLB #18
Did you install the zero start block heater? I am looking to put one in my own 110tlb.
Not yet. Because you probably have to drain the coolant, we've been putting it off. The engine air heater seems to be doing a fairly good job.
We may do the transmission heater at the same time, but have some questions: where does it go? Do you have to drain the hydraulic fluid?
   / Block Heater Deere 110TLB JD 110 TLB #20
You don't have to drain the coolant out of the 4tnv88 engine, you might lose 8-12 ounces if you're quick about it. I'm talking about the 1-inch NPT thread screw-in-heater. Just top off the radiator when you're done.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: N/A Plate: (A55853)
Year: 2017 Make...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
