Block Heater Deere 110TLB JD 110 TLB
   / Block Heater Deere 110TLB JD 110 TLB #11
the plug protector is 360-0012 ; it was just over two dollars, I know it was not necessary, but again it was only two dollars.
   / Block Heater Deere 110TLB JD 110 TLB #12
Just to confirm these are for a JD110 TLB? I cant find either part number on ZeroStart's webpage under "John Deere".
   / Block Heater Deere 110TLB JD 110 TLB #13
Here is what I did. I googled the normal/plain deere drain plug until I found an application that actually listed the size of the plug (1/2 npt if I recall) then I ordered the shortest& lowest wattage heater in that size. I have less than an hour on since the install, but as far as I know, no issues....
   / Block Heater Deere 110TLB JD 110 TLB #14
the one I ordered was 860-9624, it is 150w, there are higher wattage ones available, but without knowing exactly what deere uses, I felt better to be safe and use the lowest wattage unit.
ar87167; 120 vac, 400 watt, 36 ohm's resistance, 3.33 amps.
   / Block Heater Deere 110TLB JD 110 TLB #16
I'm not always certain that the time you waste "chasing a few dollars" is really saving much... Time or money.
I put the OEM heaters in both tranny and block. Easy peazy. And no leaks, etc.
AKfish
   / Block Heater Deere 110TLB JD 110 TLB #17
Well the ZeroStart block and tranny heater came out to $130 shipped. The Deere heaters come out to $240 (canadian). I'll take the $110 and thank all of you guys for the part numbers.
   / Block Heater Deere 110TLB JD 110 TLB #18
Did you install the zero start block heater? I am looking to put one in my own 110tlb.
Not yet. Because you probably have to drain the coolant, we've been putting it off. The engine air heater seems to be doing a fairly good job.
We may do the transmission heater at the same time, but have some questions: where does it go? Do you have to drain the hydraulic fluid?
   / Block Heater Deere 110TLB JD 110 TLB #20
You don't have to drain the coolant out of the 4tnv88 engine, you might lose 8-12 ounces if you're quick about it. I'm talking about the 1-inch NPT thread screw-in-heater. Just top off the radiator when you're done.
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2017 Kia Sorento SUV (A53424)
2017 Kia Sorento...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
