Blizzard 2015 Boston
/ Blizzard 2015 Boston #402
Yup,
We don't need no stinkin boiling water snow melting pits Mayor Walsh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Tis amazing what can be had and wasted with municipal funds when
there is a snow problem.
/ Blizzard 2015 Boston #403
Yup,
The trash would still need to be dealt with. How about a fire hydrant dumped in the melter?
I don't get the point of you being hung up on these melters. It costs nothing to watch snow melt, and we don't need to be burning more coal or other hydrocarbon fuels so we can make more crazy weather.
/ Blizzard 2015 Boston #404
This just in: the last of the Boston "snow farms" has melted. No chance for a glacier, am disappoint.
Yup,
Beg to differ.
It is cheaper and/or faster to melt the snow near the source than to try and transport it through the city. That also assumes the city has enough space to store the snow, which was not the case this winter and several others in recent memory.
MassPort has been melting the snow at Logan Airport for years. Under Menino the city would not buy them but borrowed the MassPort equipment to clear downtown. Northeastern University bought one, I believe the city purchased two, and we borrowed two from NY.
To put it in perspective, I believe the total bill in Boston was $30-35 million. Montreal is 4X bigger than Boston, but spens 5-6X as much. With Boston's crucial role in the regional economy, we should probably be spending more, not less. Of course fixing the MBTA has to be part of that equation.
/ Blizzard 2015 Boston #405
Last of the snow piles is still present! Saw it on news just a few minutes ago on WBZ (though the beautiful blonde was nicer to look at). Tons of trash on top of it but the snow/ice is still there.
Although I advocated dumping in the harbor back in Feb/ March, the enormous amount of crap of all sorts mixed with the snow is rather shocking.
/ Blizzard 2015 Boston #406
Beg to differ.
I beg to differ,
Mayor Menino obviously saw how much fuel that was consumed
by these units and passed on it.
It was an opportunity cost situation where the high cost of operation
could not justify the use versus what equipment they had in inventory
or that was loaned to them.
The portable ice and snow melting trailers are energy intensive and make
use of very little of the melt water to maintain thermal mass by using
forced air heating and a small melt tank to do the work.
Yes they melt the snow, but they lose forever the thermal mass created by
the hot water that results as it overflows to the machines spillway or
discharge hose that drains the smaller tank on the snow melter.
They can never make use of the thermal mass created in a huge pit of
near boiling water to melt the incoming ice and snow even with the
larger trailer mounted snow melters for the same reason.
They waste the melting potential of huge amount of heat energy available
from snow melt kept at a near steaming state.
As far as the garbage in the snow the pit could be equipped with waste
collection baskets that would bring any debris to the surface to be
disposed of after the baskets are dumped into a roll off container.
I still have to wonder why they have not visited Hokkaido Island to
see the snow melting systems in use there.
They use the Japanese version of the ten wheeler and other dump trucks
to the dump the snow in the vats/pits and it melts quickly in a couple of
minutes as all the water is at steaming temperature.
It would not take much flat land to install several of these systems due
to the inherent ability of water to transmit energy to the melting process.
They run these things around the clock when they have the heavy snows
which the island is famous for.
Saying that the water in a snow melting pit could be kept warm early
in the snow season with a low energy demand with low pressure
hot water boiler coal stokers that do not require licensed boiler operator to run them.
The same applies to the airport as they could use a central meting station with much
higher efficiency per ton of snow with pit melter operating at near steaming temperature
as needed.
The beautiful thing about the physics of thermal mass is it take so little energy bring it back up to a high temperature.
/ Blizzard 2015 Boston #408
Mayor Walsh announced that the last of the monster snow pile in South Boston finished melting today. Mid July. Not bad.
/ Blizzard 2015 Boston #410
Last winter we used 170 lbs of ice melter. This winte - two lbs.
My snow shovel is rusty. I also have used only a few pounds of ice melt. More importantly, we've had no snow that was big enough to cause ice dams. I've started thinking about removing snow tires too.
Of course it's only early March and I still recall the significant May snowstorm in the mid 70's.
CATERPILLAR 289D3 SKID STEER (A62129)
CATERPILLAR 289D3...
(1) Camso 15-19.5 Foam Filled Tire (A60463)
(1) Camso 15-19.5...
BE HW4013HG HOT WATER PRESSURE WASHER (A59823)
BE HW4013HG HOT...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
167 (A52708)
167 (A52708)
2017 Chevrolet Colorado Ext. Cab Pickup Truck (A61568)
2017 Chevrolet...
