Blinking light and loose steering
/ Blinking light and loose steering #1
spblc
Columbia ms
Mahindra 5530
I have an exclamation point blinking and i bought this 5530 used so i dont have an owners manual. Does anyone know what this means? Also the when i steering this tractor i make 4 or 5 rounds with the steering wheel before the tires actually start to turn. Any ideas?
/ Blinking light and loose steering #2
Count the flashes after 20min operation. Check the vacuum hoses from alternator to fip. That's the emission light. Could be vacuum leak or misadjusted throttle position sensor. On the steering check the reservoir under hood.
/ Blinking light and loose steering #3
Be sure the throttle is at its lowest setting at start-up for the blinking light issue. On the steering, what year is the tractor as I am not sure that you'll have a separate reservoir I think that your machine will pull the fluid from the gear case.
My tractor is a 2009 and has 100 hours on it...I was gonna order a manual but everything I've read nobody has been happy with the ones they have purchased. Come to think of it my lift works really slow and it hops as it's picking up the bushhog. I've owned the tractor for 4 days now and I figured with the low hours it shouldn't have any problems. The owner passed away and it has has been sitting in a barn not being used for a lil while.
/ Blinking light and loose steering #5
The owner's manual you can get from their site (although down for upgrades at the moment 24/7 Owners Login | Mahindra ). It is the shop/service manuals that need purchased. The owner's manual should provide what is needed for checking fluids and basic troubleshooting of dash lights. It does sound a lot like low fluids.
/ Blinking light and loose steering #6
Do not use the red handle to lift your implements. This handle is for draft control of ground engaging ie; plow.
Idaho2
2021 BOBCAT T62 R-SERIES SKID STEER (A64279)
2021 BOBCAT T62...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
2015 John Deere 8270R (A64119)
2015 John Deere...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
JOHN DEERE GRAIN DRILL ROW MARKERS (A64280)
JOHN DEERE GRAIN...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
