Bleeding too!!!
/ Bleeding too!!! #1
Knight9
Alberta
Kubota B2410 with turfs
My B2410 is bleeding also....just like Jezebel!! Fairly steady drip from one of the valves on the loader control box. Don't think it is too serious, but I called the dealer to schedule a check up. They will be picking it up tomorrow morning and fixing up everything immediately. Other than that drip I have had no problems. I've used the 3PH a fair bit with my blade and done some pulling from the drawbar. Lots of power and pretty decent traction even with the turfs. Hope I'm like you Jay and this is the only problem I encounter! /w3tcompact/icons/crazy.gif
Kevin
/ Bleeding too!!!
Thought I was too far away from everyone for this to be contagious!!!
Kevin
/ Bleeding too!!! #4
Kevin,
I had the same thing happen but to a lesser extent. After my tractor was first delivered I noticed a small pool of hydraulic fluid on my garage floor. I was able to trace it back to the loader control valve. It was never a steady drip in my case, but it was enough to mark up my floor which will annoy any new tractor owner, I think. I snugged up the connections at the fitting locations and that pretty well took care of it - I still get one or two drops on the loader frame. I'll probably talk with my dealer when I pick up the parts for the 50-hour service, but I'm not too worried about it.
Smooth sailing otherwise. It's a great machine isn't it/w3tcompact/icons/smile.gif?
Rob
/ Bleeding too!!!
Rob,
I thought it was just a loose fitting at first too. I snugged up the connection and it still leaks. The leak is almost non-existent when not using the FEL, but it is a pretty steady drip when the loader is being worked.
But you are right, it is a great machine, and if the dealer handles this "crisis" well, then I'll be pretty happy and comfortable with them also. Lets just hope it doesn't take too long to get her back!
Kevin
/ Bleeding too!!! #6
Kevin,
Jezebel is 100%. It was a faulty control box and it seems to be working fine. According to MB tractor it's not uncommon to have a control box to go.Your tractor should be fine after they replace the control valve.
Jason
/ Bleeding too!!!
My B2410 was delivered home again yesterday. She is looking awfully nice and clean....and best of all no drips!!! They also installed the block heater which was back-ordered when I got the tractor. Certainly don't need it now...but sure will later on in the year /w3tcompact/icons/frown.gif.
Monday is a holiday here (Victoria Day) so I have a three day weekend. Glad I got her back or it would have been a long three days. Too much to do that can't be done without her!
Kevin
/ Bleeding too!!! #8
My B7500 had a steady drip from the control valves too (at
about 10 hours).
Would turn into s pretty steady stream after it was warmed
up.
Turned out to be a bad seal; a dealer replaced it and it has
not dripped since.
/ Bleeding too!!! #9
My brand new B2410 has all sorts of drips. The first was from one of the hydralic hoses that connect up the FEL. I checked and the O-ring inside it had broken. I fixed it, and now it is dripping from both ends of one of the hoses on the left side of the FEL. Actually dripping doesn't do it justice, it is more like a slow flow. What a pain. I'm looking forward to getting some work out of this tractor, but so far I've been spending more time driving back and forth to the dealer.
Here's a link with pricing info on Kubota B series tractors.
/ Bleeding too!!! #10
Will,
Get yourself a set(about $69. large set) of open-end Craftsman wrenches from Sears and fix/tighten them yourself... {Have extra o-rings on hand as well...}
/ Bleeding too!!!
Hang in there Will!! Once you get the drips fixed up (which really should not happen when delivered new in my opinion!) you will be very happy with the tractor. I have been using my FEL a lot now that all the leaks are stopped and it has been a great little work machine.
Good luck.
Kevin
/ Bleeding too!!! #12
Thank you. That's reassuring. Every now and then I feel like I ought to try and solve my problems with a pair of vice-grips and a 3lb hammer. The dealer will install a new hose as soon as it gets in. In the meantime, I'm going to try and remain calm.
/ Bleeding too!!! #13
Well I'm back in business now. The threaded portion of one of my hydraulic hoses had split, though you couldn't see it from the outside. The dealer came over to check it out. I fired up the tractor and it did an impressive job of blowing a quart of Super UDT out the faulty coupling and all over everything. The dealer replaced the hose and everything works now.
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2000 Chevrolet Express 1500 Conversion Van (A66408)
2000 Chevrolet...
1500-gallon Poly Tank (A66408)
1500-gallon Poly...
7x16 Enclosed Spray Foam Trailer (A65563)
7x16 Enclosed...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
