Bleed The System
/ Bleed The System #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
I,m going to change the FEL hose set on my B2620. Do I need to "bleed" the system some way after the installation? It is the 4 hose set that goes from the tractor frame to the FEL.
Thanks,
Mike
/ Bleed The System #2
Generally the FEL will bleed itself in use. Cycle it up and down a couple times curling the bucket as well. It will be bled.
/ Bleed The System
Thanks Y'All . Nice weather here for "Get 'er done".
Cheers,
Mike
/ Bleed The System #4
Check the fluid after you're done cycling the cylinders with loader and 3 pt lowered to the ground. Shouldn't change all that much but still worth a look.
/ Bleed The System
Thanks ptsg.....I bought some UDT for that . It must have leaked for some time unnoticed......probably need a quart or so.
Cheers,
Mike
2017 CAT 420F2 Backhoe (A63109)
2017 CAT 420F2...
SECTION OF PALLET RACKING (A63745)
SECTION OF PALLET...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
Rhino 12ft Blade (A63118)
Rhino 12ft Blade...
CRAFTSMAN 18" CHAINSAW (A63745)
CRAFTSMAN 18"...
