bleed air from dk 35 fuel system
   / bleed air from dk 35 fuel system #1
wcsd170
jacksonville VT
kioti dk 35
tractor stopped running and belived it was fuel filter. changed filter and now can not bleed air from system. I do not understand system
   / bleed air from dk 35 fuel system #2
The lever at top of the filter has 3 positions. Center (straight up & down) is off. There is an "Air" and "ON" or Run position. Turn lever so small pointer end of lever is at "Air" position the crank engine for a few seconds, then move pointer to ON position and try starting. If it does not start, repeat the process. Just changing filter should not have drained fuel out of the injection pump so should prime quickly.
thank you, it turned out to be the injector pump not air
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A55218)
2023 NEW HOLLAND...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55301)
GALAXY - SET OF...
