bleed air from dk 35 fuel system
   / bleed air from dk 35 fuel system #1
wcsd170
jacksonville VT
kioti dk 35
tractor stopped running and belived it was fuel filter. changed filter and now can not bleed air from system. I do not understand system
   / bleed air from dk 35 fuel system #2
The lever at top of the filter has 3 positions. Center (straight up & down) is off. There is an "Air" and "ON" or Run position. Turn lever so small pointer end of lever is at "Air" position the crank engine for a few seconds, then move pointer to ON position and try starting. If it does not start, repeat the process. Just changing filter should not have drained fuel out of the injection pump so should prime quickly.
thank you, it turned out to be the injector pump not air
2001 CHEVEROLET C6500 3 CAR ROLL BACK (A54607)
2001 CHEVEROLET...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
