bleed air from dk 35 fuel system
   / bleed air from dk 35 fuel system #1
wcsd170
jacksonville VT
kioti dk 35
tractor stopped running and belived it was fuel filter. changed filter and now can not bleed air from system. I do not understand system
   / bleed air from dk 35 fuel system #2
The lever at top of the filter has 3 positions. Center (straight up & down) is off. There is an "Air" and "ON" or Run position. Turn lever so small pointer end of lever is at "Air" position the crank engine for a few seconds, then move pointer to ON position and try starting. If it does not start, repeat the process. Just changing filter should not have drained fuel out of the injection pump so should prime quickly.
thank you, it turned out to be the injector pump not air
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2016Takeuchi TL8 (A47477)
2016Takeuchi TL8...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
